[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
GRASS GIS trac at osgeo.org
Tue Feb 24 09:56:49 PST 2015
 Reporter:  annakrat                       |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  normal                         |   Milestone:  7.0.1
Component:  Display                        |     Version:  svn-trunk
 Keywords:  font, text, legend, scale bar  |    Platform:  MSWindows 8
      Cpu:  Unspecified                    |
Changes (by wenzeslaus):
  * keywords:  font => font, text, legend, scale bar
  * milestone:  7.0.0 => 7.0.1
Comment:
 Seems that this happens even on systems where it was working previously.
 Now tested on MS Windows 8 with GRASS GIS 7.0.0 (standalone).
 Adding workaround to
 [http://grasswiki.osgeo.org/wiki/WinGRASS_errors#Legend_or_scale_bar_does_not_show_any_text
 GRASS User Wiki]:
 If you add legend or scale bar to the Map Display and you see only the
 colors or the bar but not text, in the menu go to ''Settings'' >
 ''Preferences'', then select ''Map Display'' tab. Use ''Set font'' button
 to set ''Default font for GRASS displays''. From the list choose `arial`
 or another font you wish to use.
 ''BTW, there is no `7.0.0` Version in Trac. And also, is there some
 possibility to remove some `6.4.x` Versions, e.g. turn all *`RCs` into
 `releasebranch64`?''.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2448#comment:9>
