[GRASS-dev] g.mapset a bit more click-friendly (creating G_OPT_M_LOCATION ?)
Yann Chemin
ychemin at gmail.com
Tue Feb 24 17:19:53 PST 2015
Thank you Anna,
g.mapset is now working as I meant to explain,
that is that is a gisdbase is given a wrong directory,
then no Location appears in the location combo box.
Yann
> On Feb 25, 2015, at 6:28 AM, Anna Petrášová <kratochanna at gmail.com> wrote:
> On Sun, Feb 22, 2015 at 1:00 AM, Yann Chemin <ychemin at gmail.com <mailto:ychemin at gmail.com>> wrote:
> Hi Vaclav,
> looking into getting g.mapset module a bit more click-based,
> already gisdbase is selectable with G_OPT_M_DIR.
> There is already a G_OPT_M_MAPSET with a combo box, that it cool.
> It would be nice to have a similar combo box for Location selection.
> Maybe a G_OPT_M_LOCATION is needed?
> Done in r64732 and r64733.
> For location we need to have some check done directly on directory selection, or is it OK on running the module?
> I am not sure what do you mean?
> Anna
> Yann
> grass-dev mailing list
> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-dev <http://lists.osgeo.org/mailman/listinfo/grass-dev>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150225/c08d35a2/attachment.html>
