[GRASS-dev] g.extension compilation fails
Vaclav Petras wenzeslaus at gmail.com
Wed Feb 25 16:42:34 PST 2015
On Wed, Feb 25, 2015 at 2:52 PM, Isaac Ullah <isaac.ullah at asu.edu> wrote:
> #2598: g.extension compilation fails
>  Reporter:  ewcgrass  |       Owner:  grass-dev@?
>      Type:  defect    |      Status:  new
>  Priority:  normal    |   Milestone:
> Component:  Default   |     Version:  svn-releasebranch70
>  Keywords:            |    Platform:  Linux
>       Cpu:  x86-64    |
>  Running GRASS 7.0.1svn(64bit)-2015-02-21, Python 2.7.0, wxPython 2.8.12.0,
>  Linux-2.6.35.14-106.fc14.x86_64-x86_64-with-fedora-14
>  running g.extension (from gui or from command line) gives:
>  --snip--
>  g.extension extension=r.damflood svnurl=http://svn.osgeo.org/grass/grass-
>  addons/grass7
>  Fetching <r.damflood> from GRASS-Addons SVN repository (be patient)...
>  Compiling...
>  mkdir: cannot create directory `/usr/local/grass7.0.1svn-
>  x86_64-unknown-linux-gnu-21_02_2015/dist.x86_64-unknown-
>  linux-gnu': Permission denied
>  make: *** [/usr/local/grass7.0.1svn-x86_64-unknown-linux-
>  gnu-21_02_2015/dist.x86_64-unknown-linux-gnu] Error 1
>  ERROR: Compilation failed, sorry. Please check above error messages.
>  --snip--
>  where g.extension appears to be wanting to write temporary files while
>  compiling (and installing?) to a directory with root privileges, instead
>  of at $HOME/.grass7/addons which based on manual pages should be the
>  default local directory if "s" flag is not set.
> I too encountered this today. I just changed the permissions of my grass 7
> install tree in usr/lib/grass70, and it worked fine. I, too, didn't have
> any issue in grass6.4. However, I am having a different issue with
> g.extension, but only for addons I've written myself (and I made another
> e-mail thread about that).
Please, write that directly to the ticket on Trac:
http://trac.osgeo.org/grass/ticket/2598
Put there also how did you change the permissions. g.extension should
install by default to .grass7 in your how directory (or equivalent) or if
executed with sudo (or equivalent), it will put data into system directory
(neither option should require change of permissions).
Vaclav
> Isaac I Ullah, Ph.D.
> Arizona State University
> School of Human Evolution and Social Change
> PO Box 2402
> Tempe, AZ 85287-2402
> (480) 727-1054 office
> (650) 201-0479 cell
> iullah at asu.edu
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150225/0996fb6b/attachment.html>
