[GRASS-dev] [GRASS GIS] #2599: PyGRASS Raster execution error
trac at osgeo.org
Wed Feb 25 18:52:26 PST 2015
Reporter: aandre | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Python | Version: svn-releasebranch70
Keywords: raster | Platform: All
Cpu: All |
Comment(by wenzeslaus):
Replying to [ticket:2599 aandre]:
> creating my first ticket, i hope it's relevant and the way to do it.
This is definitively the way. Tickets with patch attached are greatly
appreciated. There is few things you can improve.
> I get 2 errors while executing Python scripts.
It would be good if you can post what are the steps to reproduce the error
you got. In your case probably your Python code but not the whole thing,
just minimal piece of code which produces the error (e.g. taken from
interactive command line). Use data from [http://grass.osgeo.org/download
/sample-data/ GRASS GIS NC sample dataset] to help others easily reproduce
the problem you have. In ideal case, your code can be used to create a
test case which would now expose the error and later serve as a failsafe
that the error won't happen again.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2599#comment:1>
