[GRASS-dev] [GRASS GIS] #2601: Raster query fails with unicode error
trac at osgeo.org
Fri Feb 27 00:19:06 PST 2015
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: 7.0.0
Keywords: | Platform: MSWindows XP
Cpu: Unspecified |
Tested on a fresh 7.0.0 install on XP and Vista.
Steps to reproduce - use attribute query tool on any raster map.
File "C:\Program Files\GRASS GIS 7.0.0\Python27\lib\site-
packages\wx-2.8-msw-unicode\wx\lib\mixins\treemixin.py",
line 450, in OnItemExpanding
self.RefreshChildrenRecursively(event.GetItem())
line 375, in RefreshChildrenRecursively
self.RefreshItemRecursively(child, childIndex)
line 382, in RefreshItemRecursively
item = self.DoRefreshItem(item, itemIndex, hasChildren)
line 393, in DoRefreshItem
self.RefreshItemText(item, index)
line 403, in RefreshItemText
self.__refreshAttribute(item, index, 'ItemText')
line 464, in __refreshAttribute
return getattr(self, 'Set%s'%attribute)(item, value, *args)
packages\wx-2.8-msw-unicode\wx\gizmos.py", line 647, in
SetItemText
return _gizmos.TreeListCtrl_SetItemText(*args, **kwargs)
7.0.0\Python27\lib\encodings\cp1257.py", line 15, in decode
return codecs.charmap_decode(input,errors,decoding_table)
UnicodeDecodeError
'charmap' codec can't decode byte 0x81 in position 3:
character maps to <undefined>
Using same coordinates for r.what works just fine:
(Fri Feb 27 10:13:13 2015)
r.what map=geology at PERMANENT coordinates=594416.666667,4925361.11111
594416.666667|4925361.11111||9
(Fri Feb 27 10:13:14 2015) Command finished (0 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2601>
