[GRASS-dev] winGRASS 64bit
Martin Landa
landa.martin at gmail.com
Fri Feb 27 12:16:56 PST 2015
2015-02-27 21:01 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
> 2015-02-26 1:40 GMT+01:00 Glynn Clements <glynn at gclements.plus.com>:
>> "undefined reference to __imp_xxxx" usually means that it found the
>> import library but not the corresponding DLL.
> right, it seems to be this case. Thanks for hint, Martin
regex-devel contains just a static library. Is it possible to solve
compilation issue somehow or do I need DLL lib?
Thanks, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
