#2521: d.vect.thematic, "Neither MONITOR (managed by d.mon command) nor" error
Reporter: jamesp670 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Display | Version: svn-releasebranch70
Keywords: d.vect.thematic | Platform: Linux
Cpu: x86-64 |
Comment(by martinl):
You need to enable direct rendering (1) or start graphic monitor (2) to
use d.vect.thematic. Now the module prints the error message without
traceback:
d.vect.thematic obce_polygon column=statuskod
ERROR: Neither MONITOR (managed by d.mon command) nor
GRASS_RENDER_IMMEDIATE (used for direct rendering) defined)
Start monitor:
d.mon wx0
or file-based, eg.
(1) http://grass.osgeo.org/grass71/manuals/variables.html#list-of-
selected-grass-environment-variables-for-rendering
(2) http://grass.osgeo.org/grass71/manuals/d.mon.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/2521#comment:2>
