[GRASS-dev] [GRASS GIS] #2521: d.vect.thematic, "Neither MONITOR (managed by d.mon command) nor" error
trac at osgeo.org
Thu Jan 1 17:30:27 PST 2015
Reporter: jamesp670 | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Display | Version: svn-releasebranch70
Resolution: fixed | Keywords: d.vect.thematic
Platform: Linux | Cpu: x86-64
Comment(by wenzeslaus):
Replying to [comment:2 martinl]:
> You need to enable direct rendering (1) or start graphic monitor (2) to
use d.vect.thematic.
I think that the error message is quite informative but it seems that
without documenting this behavior, people just consider this as an bug
rather than wrong usage of interface.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2521#comment:5>
