[GRASS-dev] [GRASS GIS] #995: WxGUI startup screen fails if GISDBASE path contains non-latin characters
trac at osgeo.org
Fri Jan 2 09:37:46 PST 2015
Reporter: marisn | Owner: martinl
Type: defect | Status: assigned
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-releasebranch64
Keywords: wingrass, i18n | Platform: MSWindows Vista
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:21 marisn]:
> I just tested GRASS 7 on Vista. It seems to pass the "welcome" screen
just fine, still CLI (CMD) is not set up correctly (LOCATION_NAME not
set). g.gui starts fine, still it is not possible to import any data as
vector import wizard fails to see any layers in a shapefile and raster
data importing fails when calling r.in.gdal with "file doesn't exist"
error. Exiting from CMD also fails with "Failed to start shell 'C:\Program
Files\GRASS GIS 7.0.svn\msys\bin\sh.exe'".
> My guess - elimination of CMD part on windows as per #1891 AND
elimination of touching shell in ANY way is the only solution to fix this
issue.
please could you do the test again with most recent GRASS 7.0 version?
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:22>
