[GRASS-dev] [GRASS GIS] #2525: Unable to open sqlite database if path contains non-latin letters
trac at osgeo.org
Sat Jan 3 03:41:40 PST 2015
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: wxGUI | Version: svn-releasebranch70
Keywords: | Platform: MSWindows Vista
Cpu: Unspecified |
Seems that any operation touching attribute database fails if path
contains non-latin letter.
It is a single instance of a general problem of passing file names as
arguments between GUI and modules.
Output in CMD window:
GRASS_INFO_WARNING(5668,2): Unable open database
<C:\Users\Māris\Documents\grass
data\nc_basic_spm_grass7\PERMANENT\sqlite\sqlite.db> by driver <sqlite>
GRASS_INFO_END(5668,2)
One of outputs in wxGUI command console:
Exception in thread Thread-26:
File "C:\Program Files\GRASS GIS
7.0.0svn\Python27\lib\threading.py", line 810, in
__bootstrap_inner
self.run()
7.0.0svn\gui\wxpython\gui_core\forms.py", line 374, in run
self.resultQ.put((requestId, self.request.run()))
7.0.0svn\gui\wxpython\gui_core\forms.py", line 289, in run
cparams[map]['dbInfo'] = gselect.VectorDBInfo(map)
7.0.0svn\gui\wxpython\gui_core\gselect.py", line 743, in
__init__
self._DescribeTables() # -> self.tables
7.0.0svn\gui\wxpython\gui_core\gselect.py", line 770, in
_DescribeTables
database = self.layers[layer]["database"])['cols']:
7.0.0svn\etc\python\grass\script\db.py", line 43, in
db_describe
s = read_command('db.describe', flags='c', table=table,
**args)
7.0.0svn\etc\python\grass\script\core.py", line 425, in
read_command
return handle_errors(returncode, stdout, args, kwargs)
7.0.0svn\etc\python\grass\script\core.py", line 308, in
handle_errors
returncode=returncode)
CalledModuleError: Module run None ['db.describe', '-c',
'table=census', 'driver=sqlite', 'database=C:\\Users\\M\xe2r
is\\Documents\\grassdata\\nc_basic_spm_grass7\\PERMANENT\\sq
lite\\sqlite.db'] ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
GRASS version: 7.0.0svn
GRASS SVN Revision: 63925
Build Date: 2015-01-02
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2
Note: could CommandLineToArgvW be helpful?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2525>
