[GRASS-dev] [GRASS GIS] #2526: extend r.slope.aspect to compute the values at the edges
trac at osgeo.org
Sun Jan 4 13:39:14 PST 2015
Reporter: hellik | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: slope | Platform: All
Cpu: All |
Description changed by neteler:
Old description:
> taken from the ML
> http://lists.osgeo.org/pipermail/grass-dev/2015-January/072779.html
> Another way would be to modify r.slope.aspect to compute the values at
> the edges - a second order polynomial min.square approximation
> is used to estimate the derivatives in r.slope.aspect (you get the well
> known differencing function when you do the math) and it can be used also
> to compute the values at the edge cells, but I had no luck convincing
> others that it is the right thing to do.
> I believe that any reasonable estimate is better than the current
> shrinking region (in r.flow we just propagate the same values to the
> edges), but that does not seem to be the consensus.
> Also, implementation for the edges is not straightforward because of how
> GRASS works with rows, but a smart developer could certainly do it.
> it would be nice that r.slope.aspect compute the values at the edges, at
> least as an option. I agree that any reasonable estimate is better than
> the current shrinking region.
New description:
taken from the ML
Helena Mitasova - Sun Jan 4 06:36:27 PST 2015
''Another way would be to modify r.slope.aspect to compute the values at
the edges - a second order polynomial min.square approximation is used to
estimate the derivatives in r.slope.aspect (you get the well known
differencing function when you do the math) and it can be used also to
compute the values at the edge cells, but I had no luck convincing others
that it is the right thing to do.''
''I believe that any reasonable estimate is better than the current
edges), but that does not seem to be the consensus.''
''Also, implementation for the edges is not straightforward because of
how GRASS works with rows, but a smart developer could certainly do it.''
It would be nice that r.slope.aspect compute the values at the edges, at
Ticket URL: <http://trac.osgeo.org/grass/ticket/2526#comment:1>
