[GRASS-dev] point cloud analysis: new features
Paulo van Breugel
p.vanbreugel at gmail.com
Sun Jan 4 14:00:12 PST 2015
Tried it out, and it works like a charm, great!
One question/request, would it be terribly difficult to add an option to
compute an user-defined number of clusters of equal size?
On Sun, Jan 4, 2015 at 9:02 PM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Fri, Jan 2, 2015 at 10:08 AM, Benjamin Ducke <benducke at fastmail.fm>
> wrote:
> > Hi Markus,
> > On 01/01/15 22:18, Markus Metz wrote:
> >> Hi all,
> >> a new spatial index for point data is available in lib/btree2: a
> >> multidimensional search tree, also known as k-d tree.
> > Excellent news.
> >> What is it good for:
> >> - nearest neighbor statistics: test if points are randomly
> >> distributed. The current GRASS addon v.nnstat uses an external k-d
> >> tree from PCL (which in turn uses flann) which finds the approximate,
> >> not the exact nearest neighbor. The new GRASS-native k-d tree always
> >> finds the real nearest neighbor.
> >> - spatial cluster analysis: a point cloud can be partitioned into
> >> separate clusters where points within each cluster are closer to each
> >> other than to points of another cluster. To be implemented.
> > I suggest implementing DBSCAN: http://en.wikipedia.org/wiki/DBSCAN
> > It is density-based and thus produces more useful results than
> > centroid-based methods (k-means and relatives). It can actually
> > trace the shapes of spatial clusters (even concave ones) and does
> > not require a priori knowledge about the number of clusters. It
> > can also handle noise.
> Done in trunk r63952 as v.cluster. It is not a GRASS7 addon because it
> does not work with G7.0. At the moment it only identifies and labels
> clusters. Connectivity graphs and cluster shapes are not implemented.
> In future, I would like to add OPTICS because OPTICS can better handle
> different clusters with different densities.
> Markus M
> > There is a reference implementation (albeit in Java) that you can
> > use to compare it with other clustering algorithms:
> > http://elki.dbs.ifi.lmu.de/
> > An implementation in C (that I have not tried) is here:
> > https://github.com/siddharth950/DBSCAN
> > The one drawback of DBSCAN is that it needs an efficient spatial
> > index to perform well -- and you have just taken care of that!
> >> - point cloud thinning: a sample can be generated from a large point
> >> cloud by specifying a minimum distance between sample points. To be
> >> implemented.
> >> The new k-d tree is now used by v.clean tool=snap (Vect_snap_lines()),
> >> reducing both memory consumption and processing time.
> > I would also like to point out that SAGA GIS is moving into
> > the same direction, i.e. more efficient processing of very
> > large point clouds. The latest release includes a number
> > of new point cloud tools. Perhaps it's worth a look.
> > Most importantly, SAGA GIS has introduced a new file format,
> > the SAGA Pointcloud (.spc) format. It is compact and yet
> > flexible enough for a variety of purposes. I recommend to
> > consider implementing import/export of this format in GRASS 7,
> > preferably not via v.in.ogr, to avoid the OGR model conversion
> > overhead.
> > If you think this would be an interesting option, then you can
> > find a summary on our tracker:
> > http://gvsigce.sourceforge.net/mantis/view.php?id=595
> > (we are going to implement ".spc" in gvSIG CE, as well).
> > Best wishes,
> > Ben
> >> More technical:
> >> the new k-d tree finds the exact nearest neighbor(s), not some
> >> approximation. It supports up to 255 dimensions. It is dynamic, i.e.
> >> points can be inserted and removed at any time. It is balanced to
> >> improve search performance. It provides k nearest neighbor search
> >> (find k neighbors to a given coordinate) as well as radius or distance
> >> search (find all neighbors within radius, i.e. not farther away than
> >> radius to a given coordinate).
> >> Markus M
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
> > Dr. Benjamin Ducke
> > {*} Geospatial Consultant
> > {*} GIS Developer
> > Spatial technology for the masses, not the classes:
> > experience free and open source GIS at http://gvsigce.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150104/aa5a2542/attachment-0001.html>
