[GRASS-dev] Tests down to 78% (from 84%), mostly PyGRASS
Markus Neteler neteler at osgeo.org
Mon Jan 5 06:47:08 PST 2015
On Mon, Jan 5, 2015 at 5:01 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi all,
> it seems that PyGRASS tests are down for some reason. This happened few
days
> ago between r63925 and r63939.
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-01-02-08-00/report_for_nc_spm_08_grass7_nc/testfiles.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-01-03-08-00/report_for_nc_spm_08_grass7_nc/testfiles.html
I checked this test:
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-01-02-08-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.to.rast3/test_strds_to_rast3/index.html
I tested like this:
GRASS 7.1.svn (nc_spm_08_grass7):~ > export GRASS_OVERWRITE=1
GRASS 7.1.svn (nc_spm_08_grass7):~ > python
temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
The reason is that map 'precip_i' does not contain anything:
GRASS 7.1.svn (nc_spm_08_grass7):~ > r3.univar map='precip_i'
percentile=90.0 separator=pipe -g
Like r.univar, it does not report a single line when only NULL values were
found.
Hence the test crashes.
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150105/d38c5bf2/attachment.html>
