[GRASS-dev] [GRASS GIS] #2532: TypeError: environment can only contain string when launching script on Windows
GRASS GIS trac at osgeo.org
Mon Jan 5 07:01:33 PST 2015
Windows
 Reporter:  annakrat     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  Default      |     Version:  svn-trunk
 Keywords:  encoding     |    Platform:  MSWindows 8
      Cpu:  Unspecified  |
 When launching python script in GUI - File - Launch script, I am asked to
 add the path to `GRASS_ADDON_PATH`. I did it and ran the script
 successfully. However, I am not able to run any command afterwards because
 of the python error (TypeError: environment can only contain string). The
 problem is the script path is unicode type (although I am using only ascii
 letters). The solution is to encode the script path, but with which
 encoding? And how it is going to be decoded?
 A temporary solution is to reject any scripts with path with non-ascii
 letters and just use `str()`.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2532>
