[GRASS-dev] [GRASS GIS] #2528: r.shade not in menu
GRASS GIS trac at osgeo.org
Mon Jan 5 10:18:39 PST 2015
  Reporter:  cmbarton     |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  normal       |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  unspecified
Resolution:               |    Keywords:  toolboxes, menu, r.shade
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by wenzeslaus):
 Replying to [comment:6 cmbarton]:
 > I can confirm that this is a function of the broken XML compiling. I
 tried 3 different workarounds. The 3rd one finally created the proper
 menus with the missing modules (and maybe others I hope).
 I don't know what are your workarounds. The only workaround I know about
 is to run `make` in `gui/wxpython` directory inside running GRASS session.
 This so far worked for everybody who needed that.
 The fact that GUI started for you and that you had some menus shows that
 you had some menu or toolbox XMLs somewhere. Perhaps you experimented with
 custom menus and you had something in home directory? Or you were running
 different GRASS? Or compiling to directory with existing build? Or you
 might be doing install step which I personally haven't tested much but
 there were no problems so far?
 > Since we are no longer building the menu tree manually (in theory a good
 idea), it is very important that this compiles properly.
 As I said earlier, I don't know how to fix the compilation. Martin tried
 and it helped for some cases but not for all. The best solution I can do
 is to make toolboxes independent on wxGUI which is discussed in #2142.
 However, it is important to know that this just hides the compilation
 issue by not requiring complete runtime environment during compilation,
 specifically no wxPython. I had no time to work on it so far but all I
 know is noted in the ticket, so feel free to re-assign.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:7>
