[GRASS-dev] [GRASS GIS] #2528: r.shade not in menu
GRASS GIS trac at osgeo.org
Mon Jan 5 20:08:37 PST 2015
  Reporter:  cmbarton     |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  normal       |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  unspecified
Resolution:               |    Keywords:  toolboxes, menu, r.shade
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by cmbarton):
 Replying to [comment:14 wenzeslaus]:
 > Replying to [comment:13 cmbarton]:
 > > Replying to [comment:10 wenzeslaus]:
 > > > Replying to [comment:8 cmbarton]:
 > > > > Is there some way to force an update to the menu from the command
 line after compilation?
 > > >  * compile with `make`
 > > >  * run GRASS from `dist...` directory, i.e. using `bin.../grass..`
 > > >  * `cd` into `gui/wxpython`
 > > >  * `make clean`
 > > >  * `make`
 > > > This should work. If you want to recompile the toolboxes and not the
 whole GRASS, use:
 > > >  * (in GRASS session)
 > > >  * `rm dist.../gui/wxpython/xml/*.xml`
 > > >  * `make clean`
 > > >  * `make`
 > > > If you want to script it, you probably have to start GRASS from
 command line in the demo location and set the environmental variable
 `GRASS_BATCH_JOB` to a script where you have the steps which must be
 executed inside GRASS.
 > > I'll try these. They might at least reduce the number of steps in a
 workaround. Do you think that the 2nd one will work if I'm running any
 GRASS 7 session? Or must it be the one just compiled?
 > It could work but I wouldn't do that. Mixing two different GRASS
 versions (in sense of directories/installations/compilations) will
 probably end up in some confusion. The safe way is to use GRASS in
 `dist...` and `bin...` directories of the code you are working with; this
 is the code which is used during compilation if GRASS session is needed
 (and that's the environment you are trying to fake it).
 I'd be using the same version, just a different revision. But to launch
 the GRASS in the dist folder, what is the launching script called? I don't
 see anything that is obvious.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:15>
