[GRASS-dev] [GRASS-SVN] r63958 - grass/trunk/scripts/v.to.lines
Markus Neteler neteler at osgeo.org
Tue Jan 6 00:10:51 PST 2015
On Mon, Jan 5, 2015 at 9:36 PM, <svn_grass at osgeo.org> wrote:
> Author: hellik
> Date: 2015-01-05 12:36:58 -0800 (Mon, 05 Jan 2015)
> New Revision: 63958
> Modified:
>    grass/trunk/scripts/v.to.lines/v.to.lines.py
> Log:
> v.to.lines: strip mapset
> Modified: grass/trunk/scripts/v.to.lines/v.to.lines.py
> --- grass/trunk/scripts/v.to.lines/v.to.lines.py        2015-01-05 19:32:08 UTC (rev 63957)
> +++ grass/trunk/scripts/v.to.lines/v.to.lines.py        2015-01-05 20:36:58 UTC (rev 63958)
> @@ -47,7 +47,7 @@
>  def main():
>      # Get the options
> -    input = options["input"]
> +    input = options["input"].split('@')[0]
>      output = options["output"]
>      method = options["method"]
>      min_cat = None
Hi Helli,
why is this needed? In most Python scripts I haven't seen it.
If the same map name exists in different mapsets in the SEARCH_PATH,
how would it pick the selected one?
thanks for hints,
Markus
