[GRASS-dev] [GRASS GIS] #2528: r.shade not in menu
GRASS GIS trac at osgeo.org
Tue Jan 6 12:31:32 PST 2015
  Reporter:  cmbarton     |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  normal       |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  unspecified
Resolution:               |    Keywords:  toolboxes, menu, r.shade
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by cmbarton):
 Here is an update.
 AFAICT, you can't run GRASS from the ../dist... folder on the Mac. It
 won't start because it needs environmental settings provided by packaging
 as an *.app.
 I can run another version of GRASS, cd into the source ../wxpython
 directory.
 make clean
 make
 will create the xml files
 running the following, without make clean will also generate them.
 python core/toolboxes.py > xml/menudata.xml
 python core/toolboxes.py "module_tree" > xml/module_tree_menudata.xml
 But then I have to copy the xml files into the ../dist... folder before
 making a binary package.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2528#comment:18>
