[GRASS-dev] Is grass70b4 compiling on FreeBSD ?
Wed Jan 7 08:35:23 PST 2015
Fábio Dias wrote:
> The files /usr/include/iconv.h and /usr/local/include/iconv.h are different.
Does /usr/include/iconv.h contain the macros?
	#define iconv_open libiconv_open
	#define iconv libiconv
	#define iconv_close libiconv_close
If not, it looks like it's now picking up some other iconv.h.
According to this:
https://www.freebsd.org/doc/en/books/porters-handbook/using-iconv.html
FreeBSD 10-CURRENT and later has iconv in libc, so no additional
libraries should be linked. But that will require the use of the
system iconv.h rather than a libiconv iconv.h.
> I removed the local one, re-run ./configure (both iconv related
> messages: yes) and gmake. Same deal. No -liconv included on
> include/Make/Platform.make, same error when linking.
> I also removed the --with-includedir=local and added iconv.h from another dir:
> /configure --with-includes=~/  --with-postgres --with-pthread
> --with-gdal --with-includes=/usr/local/include
> --with-libs=/usr/local/lib
> --with-freetype-includes=/usr/local/include/freetype2 --with-readline
> --with-geos --with-wxwidgets --with-lapack --with-sqlite
> Same deal. It says yes for both iconv tests and doesn't link it.
Can you show the actual compilation commands being used, specifically
for parser_interface.c in lib/gis (that's where the lib/gis -> iconv
dependency comes from; lib/driver and lib/cairodriver also have iconv
dependencies)?
