[GRASS-dev] [GRASS GIS] #2532: TypeError: environment can only contain string when launching script on Windows
GRASS GIS trac at osgeo.org
Thu Jan 8 09:13:19 PST 2015
Windows
 Reporter:  annakrat     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  Default      |     Version:  svn-trunk
 Keywords:  encoding     |    Platform:  MSWindows 8
      Cpu:  Unspecified  |
Comment(by annakrat):
 I used `EncodeString` in r63997, r63998. I tested it successfully on
 Windows (cp1252) with ascii characters and non-ascii characters which are
 not present in cp1252 result in error dialog with message how to avoid
 that. However, I failed to run the script when the name contained non-
 ascii characters present in cp1252 (á). I don't get any error, but in gui
 console I get:
 Launching script 'C:\Users\akratoc\Desktop\test_workshopá.py'...
 (Thu Jan 08 12:04:24 2015)
 Description:
  Adds the values of two rasters (A + B)
 Keywords:
  raster, algebra, sum
 Usage:
  test_workshopá.py araster=name braster=name output=name
 [--overwrite]
    [--help] [--verbose] [--quiet] [--ui]
 Flags:
  --o   Allow output files to overwrite existing files
  --h   Print usage summary
  --v   Verbose module output
  --q   Quiet module output
  --ui  Force launching GUI dialog
 Parameters:
   araster   Name of input raster A in an expression A + B
   braster   Name of input raster B in an expression A + B
    output   Name for output raster map
 ERROR: Required parameter <araster> not set:
         (Name of input raster A in an expression A + B)
 ERROR: Required parameter <braster> not set:
         (Name of input raster B in an expression A + B)
 ERROR: Required parameter <output> not set:
         (Name for output raster map)
 (Thu Jan 08 12:04:25 2015) Command finished (0 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2532#comment:5>
