[GRASS-dev] [GRASS GIS] #2537: v.external wxgui wizard: ValueError : need more than 3 values to unpack
GRASS GIS trac at osgeo.org
Fri Jan 9 01:21:08 PST 2015
 Reporter:  mlennert              |       Owner:  grass-dev@…
     Type:  defect                |      Status:  new
 Priority:  normal                |   Milestone:  7.0.0
Component:  wxGUI                 |     Version:  svn-trunk
 Keywords:  v.external postresql  |    Platform:  Linux
      Cpu:  Unspecified           |
 In freshly updated and compiled trunk and release70, I get the following
 error when I
  * open the v.external wizard in wxGUI
  * chose Database as 'Type of source'
  * chose PostgreSQL as 'Format'
  * chose a PostGIS database
   File
 "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64
 -unknown-linux-gnu/gui/wxpython/gui_core/gselect.py", line
 1362, in <lambda>
 lambda evt:
 self.SetSourceType(self.sourceMapByIdx[evt.GetInt()]))
   File
 1767, in SetSourceType
 self._reloadLayers()
   File
 1945, in _reloadLayers
 layerName, featureType, projection, geometryColumn =
 map(lambda x: x.strip(), line.split(','))
 ValueError
 This is on Debian Testing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2537>
