[GRASS-dev] [GRASS GIS] #2539: v.in.ogr: error importing shapefiles: ValueError : too many values to unpack
GRASS GIS trac at osgeo.org
Fri Jan 9 05:12:52 PST 2015
unpack
 Reporter:  richardc                 |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  critical                 |   Milestone:  7.0.0
Component:  Vector                   |     Version:  svn-releasebranch70
 Keywords:  v.in.ogr  vector import  |    Platform:  Linux
      Cpu:  x86-32                   |
 Probably related to https://trac.osgeo.org/grass/ticket/2537
 I'm getting the following error on attempting to import a shape file,
 without success, with v.in.ogr.
 Layer Manager > File > Import vector data > Common import formats
 [v.in.ogr] Browse to select file
 From the command console:
   File "/usr/lib/python2.7/dist-
 packages/wx-2.8-gtk2-unicode/wx/lib/filebrowsebutton.py",
 line 140, in OnChanged
 self.changeCallback(evt)
   File "/home/rcooper/grass70/grass-7.0.0svn/gui/wxpython/gu
 i_core/gselect.py", line 1920, in OnUpdate
 self._reloadLayers()
 i_core/gselect.py", line 1945, in _reloadLayers
 layerName, featureType, projection = map(lambda x:
 x.strip(), line.split(','))
 ValueError
 And after clicking Import, I receive the following popup message:
 No layers selected. Operation canceled
 The above relates to 7.0.0svn:
 System Info
 GRASS version: 7.0.0svn
 GRASS SVN Revision: 63929
 Build Date: 2015-01-02
 Build Platform: i686-pc-linux-gnu
 GDAL/OGR: 1.11.1
 PROJ.4: 4.9.0
 GEOS: 3.4.2
 SQLite: 3.7.9
 Python: 2.7.3
 wxPython: 2.8.12.1
 Platform: Linux-3.2.0-31-generic-pae-i686-with-LinuxMint-13-maya
 I've tried with a couple of shapefiles.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2539>
