[GRASS-dev] [GRASS GIS] #2541: wxgui vector import wizard: ValueError : too many values to unpack
trac at osgeo.org
Fri Jan 9 05:15:12 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-releasebranch70
Keywords: wxGUI vector import | Platform: Unspecified
Cpu: Unspecified |
Reported on the users mailing list:
"Hi,
I'm getting the following error on attempting to import a shape file,
without success, with v.in.ogr:
From the command console:
File "/usr/lib/python2.7/dist-
packages/wx-2.8-gtk2-unicode/wx/lib/filebrowsebutton.py",
line 140, in OnChanged
self.changeCallback(evt)
File "/home/user/grass70/grass-7.0.0svn/gui/wxpython/gu
i_core/gselect.py", line 1920, in OnUpdate
self._reloadLayers()
i_core/gselect.py", line 1945, in _reloadLayers
layerName, featureType, projection = map(lambda x:
x.strip(), line.split(','))
ValueError
And after clicking Import, I receive the following popup message:
No layers selected. Operation canceled
The above relates to 7.0.0svn:
System Info
GRASS version: 7.0.0svn
GRASS SVN Revision: 63929
Build Date: 2015-01-02
Build Platform: i686-pc-linux-gnu
GDAL/OGR: 1.11.1
PROJ.4: 4.9.0
GEOS: 3.4.2
SQLite: 3.7.9
Python: 2.7.3
wxPython: 2.8.12.1
Platform: Linux-3.2.0-31-generic-pae-i686-with-LinuxMint-13-maya
I've tried with a couple of shapefiles.
Cheers,
Richard"
I can confirm this bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2541>
