[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
GRASS GIS trac at osgeo.org
Mon Jan 12 00:39:02 PST 2015
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  unspecified
 Keywords:  standardized options  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by mlennert):
 Replying to [comment:189 glynn]:
 > Replying to [comment:187 wenzeslaus]:
 > > `r.mapcalculator` may create some confusion because is not part of
 standard GRASS GIS distribution (compilation switched off by default). It
 is also not in the documentation. I don't know if the confusion is also on
 the QGIS site. Another issue is that it is in Shell, not Python, so it
 should not work in GRASS 7 on MS Windows as far as I understand. Finally,
 so revision of messages is needed, error message "Calculating
 $GIS_OPT_OUTFILE. Try expert mode." shown after `r.mapcalc` failed just
 caught my eye.
 > r.mapcalculator was never converted to Python. It was deemed unnecessary
 now that r.mapcalc uses G_parser(). r.mapcalculator was created when
 r.mapcalc didn't use G_parser() which meant that it couldn't generate a
 GUI option dialog.
 > If there's some situation where it's useful, it should be converted to
 Python. Otherwise, it should be removed from the 7.0 tree.
 +1 for removal. If there are any issues with using the grass7 r.mapcalc in
 other software (e.g. QGIS) then let's try to solve these issues.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:191>
