[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
GRASS GIS trac at osgeo.org
Mon Jan 12 05:52:03 PST 2015
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  unspecified
 Keywords:  standardized options  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by neteler):
 Replying to [comment:183 neteler]:
 >  * r.param.scale: param -> method?
 >  * r.walk; percent_memory -> memory?
 Done in r64088 + r64089.
 > v.lidar.correction
 >        sce   Interpolation spline step value in east direction
 >              default: 25
 >        scn   Interpolation spline step value in north direction
 >              default: 25
 > --> ew_step/ns_step (as in v.surf.bspline)
 > v.lidar.edgedetection
 >        see   Interpolation spline step value in east direction
 >              default: 4
 >        sen   Interpolation spline step value in north direction
 >              default: 4
 > No idea if the default values should be the same?
 Parameters renamed in r64083/r64085 + r64084/r64086.
 The default values I have still left as before.
 TODO: r.mapcalculator, r.reclass.area entry in lib/gis/renamed_option
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:192>
