[GRASS-dev] [GRASS GIS] #2539: v.in.ogr: error importing shapefiles: ValueError : too many values to unpack
trac at osgeo.org
Mon Jan 12 08:18:15 PST 2015
unpack
Reporter: richardc | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: wxGUI | Version: svn-releasebranch70
Keywords: wxgui vector import wizard | Platform: Linux
Cpu: x86-32 |
Comment(by mlennert):
Replying to [comment:3 martinl]:
> I cannot reproduce this bug. Please can you check it again with the
fresh installation?
I have trouble finding a clear logic in all this as sometimes it seems to
work and sometimes not. But I think I found a candidate of what might
explain it
[http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.external/list.c#L326
1], but only with gdal < 1.11 :
312 #if GDAL_VERSION_NUM >= 1110000
313 for (igeom = 0; igeom <
OGR_FD_GetGeomFieldCount(Ogr_featuredefn); igeom++) {
314 Ogr_geomdefn =
OGR_FD_GetGeomFieldDefn(Ogr_featuredefn, igeom);
315 if (!Ogr_geomdefn) {
316 G_warning(_("Invalid geometry column %d"),
igeom);
317 continue;
318 }
319
320 Ogr_geom_type =
OGR_GFld_GetType(Ogr_geomdefn);
321 fprintf(fd, "%s,%s,%d,%s\n", layer_name,
322
feature_type(OGRGeometryTypeToName(Ogr_geom_type)),
323 proj_same,
OGR_GFld_GetNameRef(Ogr_geomdefn));
324 }
325 #else
326 fprintf(fd, "%s,%s,%d,\n", layer_name,
327
328 proj_same);
329 #endif
Line 326 reads:
should the last comma really be there ? Erasing it away seems to solve the
problem for me.
However, this would not explain the problem for RichardC as he seems to be
working with gdal 1.11...
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2539#comment:4>
