[GRASS-dev] module header definitions add: text/multiline and latex support?
Nikos Alexandris nik at nikosalexandris.net
Wed Jan 14 10:15:38 PST 2015
On 14.01.2015 19:13, Paulo van Breugel wrote:
> These text elements could help to unclutter the interface if used
> properly.
> Like the example provided by Pietro, they could for example help to
> group
> the inputs from which the user need to select one (grouping of
> options
> using tabs is another option, but not always a good one).
I agree, tabbing is always efficient.  Just an idea:  instead of
"tabbing", could the "guisection", or a similar function, stack stuff in
a box with slightly, yet distiguishable, different colored background?
Along with other stuff in the same tab?
> Yes, from the manual page the user can find out he/she needs to
> select one, but I am
> convinced that for many it would be beneficial if it also is clear at
> one
> glance from the interface.. similar to how the red asterisk helps the
> user
> to see at one glance which parameters are obligatory.
Note, the "tooltips" pop only when the cursor floats over some
descriptive text.  Can they also appear when the cursor points directly
in an/the input box?
Nikos
