[GRASS-dev] module header definitions add: text/multiline and latex support?
Huidae Cho grass4u at gmail.com
Wed Jan 14 23:49:43 PST 2015
On Thu, Jan 15, 2015 at 2:46 AM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> > Requiring raster OR vector is possible already.
> > #%rules
> > #% requires: raster, vector
> > #%end
> This should be "required" (at least one of the options must be given).
> If you want exactly one option to be given, you need both "required"
> and "exclusive", e.g.
> #%rules
> #% required: raster, vector
> #% exclusive: raster, vector
> #%end
> A "requires" rule indicates that if the first option is given, at
> least one of the other options must be given.
You're right. I was thinking about "required", but my hands typed
"requires" :-(
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150115/199b9835/attachment.html>
