[GRASS-dev] (win)GRASS compiling:
Helmut Kudrnovsky
hellik at web.de
Thu Jan 15 06:44:43 PST 2015
hi,
I've just compiled winGRASS7.0.0 RC1, compilation went without errors.
although by scanning the log, I've found e.g.
Status: Parsing c:\users\myrica~1\appdata\local\temp\tmp0piwel.h
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/sys/types.h:27:
Syntax error at '__time32_t'
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/sys/types.h:45:
Syntax error at 'time_t'
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/io.h:66:
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/io.h:71:
Syntax error at '}'
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/io.h:75:
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/io.h:80:
Syntax error at '}'
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/io.h:127:
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/io.h:132:
Syntax error at '}'
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/io.h:136:
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/io.h:141:
Syntax error at '}'
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/sys/stat.h:96:
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/sys/stat.h:114:
Error:
c:\\osgeo4w\\bin\\../lib/gcc/mingw32/4.7.2/../../../../include/sys/stat.h:131:
Status: Processing description list.
Warning: Member "from" of Struct "DateTime" has been renamed to "_from"
because it has the same name as a Python keyword.
some log extract attached:
wingrasscompilation.txt
<http://osgeo-org.1560.x6.nabble.com/file/n5181694/wingrasscompilation.txt>
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/win-GRASS-compiling-tp5181694.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
