[GRASS-dev] [GRASS GIS] #2550: Polygons disappear after v.generalize simplification
trac at osgeo.org
Fri Jan 16 13:44:20 PST 2015
Reporter: dido | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.5
Component: Vector | Version: 6.4.4
Keywords: Polygons disappear v.generalize simplification | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by mmetz):
Replying to [ticket:2550 dido]:
> Polygons disappear after v.generalize simplification.
> A large rectangular polygon dataset is used with ~14 000 features.
> Polygons are first processed with rmarea to remove all polygons of size
900 m2. Then a simplification is executed with v.generalize using a factor
of 10, all other parameters defaulted.
> After simplification several large polygons are missing from the set
rendering it useless.
> System is a win7x64; QGIS 2.6.1 and GRASS 6.4.4
> Dataset can be provided upon request (being a 7.5mb shapefile).
I assume the workflow is v.in.ogr + v.clean tool=rmarea + v.generalize
threshold=10.
Several functions relating to v.generalize have just been fixed in trunk
and I would like to test. Can you please provide a link to the shapefile
or send the shapefile to markus.metz.giswork at gmail dot com? Thanks!
Ticket URL: <http://trac.osgeo.org/grass/ticket/2550#comment:1>
