[GRASS-dev] [GRASS GIS] #2532: TypeError: environment can only contain string when launching script on Windows
trac at osgeo.org
Sat Jan 17 07:13:12 PST 2015
Windows
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: encoding | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:11 annakrat]:
> Replying to [comment:10 glynn]:
> > Replying to [comment:8 annakrat]:
> It gives me False. I will try to see if there is something wrong in the
gui part.
I found that there is raised and ignored exception
[http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/core/gconsole.py#L554
here] and if I remove the try except block, I get:
File "C:\Users\akratoc\Programs\GRASS GIS
7.1.svn\gui\wxpython\lmgr\frame.py", line 907, in
OnRunScript
self._gconsole.RunCmd([filename])
7.1.svn\gui\wxpython\core\gconsole.py", line 554, in RunCmd
task = gtask.parse_interface(command[0])
7.1.svn\etc\python\grass\script\task.py", line 509, in
parse_interface
tree = etree.fromstring(get_interface_description(name))
7.1.svn\etc\python\grass\script\task.py", line 465, in
stderr=PIPE)
7.1.svn\etc\python\grass\script\core.py", line 62, in
__init__
subprocess.Popen.__init__(self, args, **kwargs)
7.1.svn\Python27\lib\subprocess.py", line 711, in __init__
errread, errwrite)
7.1.svn\Python27\lib\subprocess.py", line 922, in
_execute_child
args = '{} /c "{}"'.format (comspec, args)
UnicodeEncodeError
'ascii' codec can't encode character u'\xe1' in position 38: ordinal not
in range(128)
The `command[0]` is Unicode. It seems Popen in Python 2.7 can't handle
non-ascii characters. So I tried to encode the command string and I get
different error:
OnRunScript
7.1.svn\gui\wxpython\core\gconsole.py", line 555, in RunCmd
task = gtask.parse_interface(EncodeString(command[0]))
parse_interface
7.1.svn\Python27\lib\xml\etree\ElementTree.py", line 1300,
in XML
parser.feed(text)
7.1.svn\Python27\lib\xml\etree\ElementTree.py", line 1642,
in feed
self._raiseerror(v)
7.1.svn\Python27\lib\xml\etree\ElementTree.py", line 1506,
in _raiseerror
raise err
xml.etree.ElementTree
ParseError
syntax error: line 1, column 0
It seems that `get_interface_description` returns empty xml. I didn't have
time to look into it further.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2532#comment:13>
