[GRASS-dev] ubuntu 7.0.0RC1
Will Fields
will.openfields at gmail.com
Sat Jan 17 09:35:59 PST 2015
Hi Martin,
I received a similar error on Mint 17.1, 64-bit (Ubuntu 14.04):
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
grass70 : Depends: grass70-core but it is not going to be installed
Depends: grass70-gui but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I'm pretty sure I had checked to the dependencies before trying to install
things, but I'm verifying that now. Is there any other information that
would be useful to troubleshoot this?
Thanks,
Will
On Fri, Jan 16, 2015 at 5:01 PM, Blumentrath, Stefan <
Stefan.Blumentrath at nina.no> wrote:
> Hi Martin,
> Just tested the procedure and got unmet dependency errors (on Ubuntu 12.04
> LTS 32bit). First grass70-core and grass70-gui were missing, but when I
> added them:
> sudo apt-get install grass70 grass70-core grass70-gui
> I still get unmet dependencies errors, but without information about which
> packages are missing...
> My full error-messages are in german, so I do not know how helpful they
> would be for you... I can send them if you are interested... Maybe I should
> notice that I have a self-compiled GDAL installation...
> Cheers
> Stefan
> >I recently published RC1 packages for Ubuntu. Could any Ubuntu >user
> >here to test the procedure bellow:
> >sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
> >sudo add-apt-repository ppa:grass/grass-stable
> >sudo apt-get update
> >Thanks, Martin
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150117/964e28f2/attachment.html>
