[GRASS-dev] porting i.spec.sam to grass7
Vaclav Petras wenzeslaus at gmail.com
Mon Jan 19 08:54:40 PST 2015
On Mon, Jan 19, 2015 at 11:31 AM, Yann Chemin <ychemin at gmail.com> wrote:
> Hi,
> porting to grass7 i.spec.sam (grass-addons/grass7/imagery/)
> I am getting a set of complaints like this:
> OBJ.x86_64-unknown-linux-gnu/spec_angle.o:(.bss+0x158): multiple
definition of `Avector'
OBJ.x86_64-unknown-linux-gnu/main.o:/home/yann/dev/grass-addons/grass7/imagery/i.spec.sam/main.c:92:
first defined here
> while it is actually defined in global.h, and global.h is read in main.c
as well as in spectral_angle.c . The line 92 in main.c is the first
appearance, without declaring Avector (just using it).>
You just miss an "include guard":
 #ifndef GRANDFATHER_H
 #define GRANDFATHER_H
 struct foo {
     int member;
 #endif /* GRANDFATHER_H */
(example from http://en.wikipedia.org/wiki/Include_guard)
Compare:
http://trac.osgeo.org/grass/browser/grass-addons/grass6/imagery/i.spec.sam/global.h?rev=50996
http://trac.osgeo.org/grass/browser/grass-addons/grass7/imagery/i.edge/gauss.h?rev=52501
> Yann
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150119/16beec99/attachment.html>
