[GRASS-dev] Unifing naming of 3D rasters
Vaclav Petras wenzeslaus at gmail.com
Tue Jan 20 19:37:49 PST 2015
On Tue, Jan 20, 2015 at 4:05 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Jan 20, 2015 at 9:56 PM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > I was not able to change text in the "layout" image. As the README says,
> > "the source file r3_volume_layout.xcf is probably broken." What about
> some
> > older versions?
> I have replaced it in SVN by downloading the older version (with same
> content as far as I can see):
> http://trac.osgeo.org/grass/browser/grass/trunk/lib/raster3d/g3d_volume_layout.xcf?rev=47531
> Now it is at least no longer corrupted.
> I changed the image in GIMP and did all the related changes in 64270.
http://trac.osgeo.org/grass/changeset/64270
> > Is there some scriptable way to redo the image? Perhaps
> > using matplotlib? I hope we will be able to do it at least for 7.1.
> Soeren may know...
> Not much need now since you found the working version, however it would be
still useful to be able to create the image in some simple way (although
learning Paraview might generally useful).
Markus
> > Vaclav
> > http://grass.osgeo.org/grass71/manuals/r3_volume_layout.png
> > http://grass.osgeo.org/grass71/manuals/raster3dintro.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150120/8c9f0b68/attachment.html>
