[GRASS-dev] [GRASS GIS] #2556: v.colors: copying from raster map does not work as expected
trac at osgeo.org
Thu Jan 22 07:49:11 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Keywords: v.colors raster | Platform: Unspecified
Cpu: Unspecified |
v.colors map=censusblk_swwake at PERMANENT use=attr column=MEDIAN_AGE
color=elevation
works as expected.
g.region vect=censusblk_swwake res=2 -ap
v.to.rast input=censusblk_swwake at PERMANENT output=census use=attr
attribute_column=MEDIAN_AGE
r.colors map=census at user1 color=elevation
raster=census at user1
Only a small part of the census blocks is in color.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2556>
