[GRASS-dev] Making start of GRASS GIS easier for newcomers
Markus Metz
markus.metz.giswork at gmail.com
Fri Jan 23 05:30:01 PST 2015
On Fri, Jan 23, 2015 at 1:14 PM, Yann Chemin <ychemin at gmail.com> wrote:
> On 23 January 2015 at 16:49, Rainer M Krug <Rainer at krugs.de> wrote:
>> Yann Chemin <ychemin at gmail.com> writes:
>> > On 23 January 2015 at 15:46, Martin Landa <landa.martin at gmail.com>
>> > wrote:
>> >> Hi,
>> >> 2015-01-23 9:20 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
>> >> > my motivation to discuss the current welcome screen is that too many
>> >> > potential new users try to launch GRASS, do not get past that screen
>> >> > and
>> >> > walk away ("too difficult"). Yes, and they will likely not read the
>> >> manual
>> >> > but just take another GIS.
>> >> > This is a multiple times reported fact.
>> >> I have met a lot of GIS specialists who told me: I tried several times
>> >> to use GRASS in different decades and I end up with the same result, I
>> >> didn't managed to get my data in, so I gave up.
>> >> Yes, I also had those experiences told to me.
>> > Is it possible to open GRASS GIS wxGUI without setting the
>> > GISDB/Location/mapset yet?
>> > Then from "inside the opened software" you will need to go through those
>> > steps anyway before doing anything...
>> > Would that make any psychological difference?
>> I think this would make a huge difference - especially if the creation
>> could be done by triggerd upon import and
> hmm that would be cool !
> running r(v).in.* without GISDBASE or Location or mapset could trigger a
> wizard to set them up...
This is the current location wizard.
The original topic was import and on-the-fly reprojection without the
need to create a new location. This can be easily done by either a new
script that calls r.in.gdal/v.in.ogr + r.proj/v.proj which creates the
new location internally and deletes it when done, or a wizard doing
the same thing. The user does not even notice that a temporary
location was created. Sextante for example works this way.
Markus M
>> - asking for a directory (for the db),
>> - name of the location,
>> - name of the mapset, and
>> - taking the other parameter (projection, extend) from the data to be
>> imported.
>> Until a mapset is opened, the non-usable menu items could be greyed
>> out.
> Sounds like a nice option, as it will direct newbies to modules that import
> data (then trigger the creation wizard)
>> Rainer
>> >> It' a sign in my eyes that we should think how to simplify this step
>> >> Martin
>> >> Martin Landa
>> >> http://geo.fsv.cvut.cz/gwiki/Landa
>> >> http://gismentors.eu/mentors/landa
>> >> _______________________________________________
>> >> grass-dev mailing list
>> >> grass-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Rainer M. Krug
>> email: Rainer<at>krugs<dot>de
>> PGP: 0x0F52F982
