[GRASS-dev] Build errors for GRASS 7.1 on Ubuntu?
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Jan 29 02:51:38 PST 2015
Thanks for the hint. I should have known that (as it also is written in the make output), sorry.
Seems to be my self-compiled GDAL/OGR which is making problems...
First error is in "grass7_trunk/db/drivers/ogr":
/usr/local/lib/libgdal.so: undefined reference to `G__setenv'
collect2: error: ld returned 1 exit status
I suspect I have to update GDAL/OGR, but that I will do only on my private computer as I do not want to interfere with our production environment for testing purposes...
Thanks for helping so far. I shall try to test t.what.rast tonight then.
Kind regards,
Stefan
-----Original Message-----
From: Markus Metz [mailto:markus.metz.giswork at gmail.com]
Sent: 29. januar 2015 11:33
To: Blumentrath, Stefan
Cc: Markus Neteler; GRASS developers list
Subject: Re: [GRASS-dev] Build errors for GRASS 7.1 on Ubuntu?
On Thu, Jan 29, 2015 at 11:13 AM, Blumentrath, Stefan <Stefan.Blumentrath at nina.no> wrote:
> Hi,
> and thanks for looking at this.
> The first error which occurs is here (line 3080):
You need to report the first error in the list of directories with errors, i.e. the first entry after "Errors in:".
Then you need to deal with the errors in the order they appear in this
list: go to the first directory, run make and report.
I suspect you need to make distclean, check svn status, solve conflicts, configure anew and make again.
Markus M
> Status: Parsing /tmp/tmp0RJahD.h
> Status: Processing description list.
> Warning: Could not load library "grass_vedit.7.1.svn". Okay, I'll try
> to load it at runtime instead.
> Status: Writing to OBJ.x86_64-unknown-linux-gnu/vedit.py.
> Status: Wrapping complete.
> sed -f fix.sed OBJ.x86_64-unknown-linux-gnu/vedit.py >
> /data/src/grass7_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/
> lib/vedit.py
> python -t -3 -m py_compile
> lib/vedit.py
> Status: Preprocessing /tmp/tmpmQgkHh.h
> Status: gcc -E
> -I/data/src/grass7_trunk/dist.x86_64-unknown-linux-gnu/include
> -D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__="
> "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
> "-D__asm(x)=" "-DCTYPESGEN=1" /tmp/tmpmQgkHh.h
> Status: Parsing /tmp/tmpmQgkHh.h
> Error: /usr/include/GL/gl.h:90: Syntax error at '\n'
> Error: /usr/include/GL/gl.h:93: Syntax error at '\n'
> Warning: Could not load library "grass_ogsf.7.1.svn". Okay, I'll try
> Does that help to identify the issue?
> Cheers
> Stefan
> From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On
> Behalf Of Markus Neteler
> Sent: 29. januar 2015 09:40
> Cc: GRASS developers list
> On Jan 29, 2015 9:30 AM, "Blumentrath, Stefan"
> wrote:
>> Dear all,
>> I was just about to test Sörens new t.rast.what module but it seems
>> that I have to update my installation of GRASS 7 (trunk) first.
>> Unfortunately, I get a lot of build errors with r64351 on Ubuntu
>> 14.04…
>> This is how I configure:
>> CFLAGS="-O2 -msse -msse2 -mfpmath=sse -minline-all-stringops -g -Wall"
>> LDFLAGS="-s" ./configure --with-cxx --with-sqlite --with-postgres
>> --with-postgres-includes=/usr/include/postgresql --with-odbc
>> --with-cairo --with-proj-share=/usr/local/share/proj
>> --with-tcltk-includes=/usr/include/tcl8.4/ --with-freetype
>> --with-freetype-includes=/usr/include/freetype2 --with-fftw
>> --with-nls --with-python --with-tiff --with-geos --enable-largefile
>> --with-readline --with-blas --with-glw --with-motif --with-openmp
>> --with-wxwidgets --with-pthread --with-liblas --with-netcdf
>> --with-lapack
>> ./configure runs without issues, but on make I get errors in more
>> than
>> 40/50 modules (gui, raster, vector, temporal, db).
> The first error in the list is relevant. The rest may depend on it.
>> One of the error messages is a syntax error in a header file:
> That's normal. Please check for the first listed lib or module in the
> error file, cd into it and run make to see the error.
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
