[GRASS-dev] Getting version number *before* starting
Rainer M Krug Rainer at krugs.de
Fri Jan 30 01:44:29 PST 2015
Vaclav Petras <wenzeslaus at gmail.com> writes:
> On Thu, Jan 29, 2015 at 5:20 PM, Blumentrath, Stefan <
> Stefan.Blumentrath at nina.no> wrote:
>>  What about grass70 --config?
>> Cheers
>> Stefan
> --config does not work for 64.
unfortunately not - but one could always make an exception for 64.
> For 70 it does not give version, only revision (of library I think). We
> should probably change the format to be more parseable. The line order is
> really not stable, I'm not sure what other do.
> $ grass71 --config
> x86_64-unknown-linux-gnu
> ./configure  --enable-largefile=yes --with-nls --with-cxx --with-readline
> --with-pthread --with-proj-share=/usr/share/proj
> --with-geos=/usr/bin/geos-config --with-wxwidgets --with-cairo
> --with-opengl-libs=/usr/include/GL --with-freetype=yes
> --with-freetype-includes=/usr/include/freetype2/ --with-postgresql=yes
> --with-postgres-includes=/usr/include/postgresql --with-sqlite=yes
> --with-mysql=yes --with-mysql-includes=/usr/include/mysql --with-odbc=no
> --with-liblas=yes --with-liblas-config=/usr/bin/liblas-config
> gcc
> /home/vasek/dev/grass/gcc_trunk/dist.x86_64-unknown-linux-gnu
> 63639
> 70 --help has actually version number on the first line as 64 --version has
> but 64 --help does not have the version, except for usage (at least the one
> from Ubuntu package).
> I'm afraid we have to implement something better. What would it be?
A parsable format would be really nice here, as most of the information
needed is here.
Some standard fields as
- MAJOR version (e.g. 7)
- MINOR version (e.g. 1)
- PATCH version (e.g. 0)
- version EXTENSION (e.g. alpha)
- REVISION
- PLATFORM (e.g. x86_64-unknown-linux-gnu)
- grass BASE directory (e.g.
/home/vasek/dev/grass/gcc_trunk/dist.x86_64-unknown-linux-gnu) (I
assume the bin/ is in the base directory?)
- the CONFIGURE options - possibly split into separate and multiple
entries
A format like the Debian Control Files Syntax [1], which is defined and
easily parsable from different languages, would be the easiest.
I don't know if something like this can be still incorporated into
7.0.0?
This would be really nice and useful.
Thanks,
Rainer
>> *From:* grass-dev-bounces at lists.osgeo.org [mailto:
>> grass-dev-bounces at lists.osgeo.org] *On Behalf Of *Vaclav Petras
>> *Sent:* 29. januar 2015 23:10
>> *To:* Rainer M Krug
>> *Cc:* grass-dev at lists.osgeo.org
>> *Subject:* Re: [GRASS-dev] Getting version number *before* starting
>> On Thu, Jan 29, 2015 at 9:51 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Hi
>> I would, for implementation in spgrass7 in R, to be able to get the version
>> number of GRASS GIS before starting GRASS.
>> I know about the --version parameter of grass command.
>> $ grass64 --version
>> GRASS GIS 6.4.4
>> Geographic Resources Analysis Support System (GRASS) is Copyright,
>> 1999-2014 by the GRASS Development Team, and licensed under terms of the
>> GNU General Public License (GPL) version >=2.
>> This GRASS 6.4.4 release is coordinated and produced by the...
>> Unfortunately for GRASS GIS 7 it is giving more the license and about then
>> the version:
>> $ grass71 --version
>> This GRASS 7.1.svn release is coordinated and produced by
>> Although, I'm running 71 from source code, so it might be different.
>> To get general idea, here are examples what other projects have in
>> --version:
>> gcc --version
>> gcc (Ubuntu 4.8.2-19ubuntu1) 4.8.2
>> Copyright (C) 2013 Free Software Foundation, Inc.
>> This is free software; see the source for copying conditions.  There is NO
>> pandoc --version
>> pandoc 1.12.2.1
>> Compiled with texmath 0.6.5.2, highlighting-kate 0.5.5.1.
>> Syntax highlighting is supported for the following languages:
>> I know that in the file
>> | GRASS_BASE_DIRECTORY/etc/VERSIONNUMBER
>> the version number is stored, but I have two questions:
>> 1) is this the same between systems (I saw it in Mac Linux and Windows)?
>> 2) I assume the location of this file is very un-likely to change?
>> 3) can the internal structure of the GDRASS_BASE_DIRECTORY be configured
>> during the build process (particularly the bin/ and the location of
>> VERSIONNUMBER), and if yes, how can I obtain the location of these folders?
>> So: would there be any downside in just reading this file to determine
>> the version of GRASS GIS, as the grass startup script seems to be
>> reading from that file as well?
>> Thanks,
>> Rainer
>> Rainer M. Krug
>> email: Rainer<at>krugs<dot>de
>> PGP: 0x0F52F982
>> grass-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Footnotes:
[1]  http://www.debian.org/doc/debian-policy/ch-controlfields.html
Rainer M. Krug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150130/94006d81/attachment.pgp>
