[GRASS-dev] [GRASS GIS] #2568: Upper-lower case issues with sqlite driver and affect on v.db.reconnect.all
trac at osgeo.org
Fri Jan 30 12:44:48 PST 2015
Reporter: ewcgrass | Owner: grass-dev@…
Type: defect | Status: closed
Priority: major | Milestone: 7.0.0
Component: Database | Version: svn-releasebranch70
Resolution: fixed | Keywords:
Platform: Linux | Cpu: x86-64
Changes (by ewcgrass):
* status: new => closed
* resolution: => fixed
Comment:
Thanks for solving this so quickly. I missed that entirely because having
different key column names never negatively affected doing work with the
vector file attribute data in GRASS 6.4. Running v.db.connect map= key=cat
in GRASS 6.4 before migrating fixes the problem, as it does running
v.db.connect map= key=CAT in GRASS 7.0 after migrating from .dbf to
sqlite!
v.db.reconnect.all still hangs at every other database error it encounters
during migration (eg. syntax issues re. column names vs sqlite keywords,
quotes or squiggles in table data, dropping columns due to name length >10
in the .dbf table which for odd reasons were never caught earlier, etc.).
But I guess this is not all bad, as it is an opportunity to clean up
database files? About 300 dbf tables migrations completed, about 1200 more
to go.
Perhaps this Ticket should be changed from a "bug" to a "wish", where
v.db.reconnect.all could perhaps be modified to catch these migration
errors more graciously?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2568#comment:2>
