[GRASS-dev] New wiki page summarising GRASS APIs
Pietro
peter.zamb at gmail.com
Sat Jan 31 02:06:59 PST 2015
Hi Moritz,
On Fri, Jan 30, 2015 at 5:02 PM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> In preparation of a talk at the geospatial devroom at the FOSSDEM this
> weekend, I've elaborated a wiki page on the current GRASS GIS APIs:
> http://grasswiki.osgeo.org/wiki/GRASS_GIS_APIs
Thank you for the work that you have done! Some brief notes:
Why os.system?
import os
os.system('g.region rast=elevation')
and not subprocess:
import subprocess
subprocess.call('g.region rast=elevation', shell=True)
# or
subprocess.Popen('g.region rast=elevation', shell=True)
Concerning the pygrass Module API, may be we can use the shortcut version:
>>> from grass.pygrass.modules.shortcuts import general as g
>>> gregion = g.region(flags='p') # return a Module class instance
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 318500
south: -16000
west: 124000
east: 963000
nsres: 500
ewres: 500
rows: 669
cols: 1678
cells: 1122582
>>> gregion
Module('g.region')
>>> gregion.name
'g.region'
>>> gregion.description
'Manages the boundary definitions for the geographic region.'
>>> gregion.flags.p = False # change previous flag to False
>>> gregion.flags.g =True # set the g flag to True
>>> gregion.run()
n=318500
s=-16000
w=124000
e=963000
nsres=500
ewres=500
rows=669
cols=1678
cells=1122582
Module('g.region')
>>> gregion.inputs.raster = 'elevation'
>>> gregion.run()
n=318500
s=-16000
w=124000
e=963000
nsres=500
ewres=500
rows=669
cols=1678
cells=1122582
In the Census example, we should add census.close() to close the
vector map after the use, or use the with statement:
>>> with VectorTopo('census', mode='r') as census:
... print('numb. areas:', census.number_of('areas'))
... for area in census.viter('areas'):
... if area.area()>4000000:
... print(area.id, area.area())
All the best
Pietro
