[GRASS-dev] [GRASS GIS] #2634: 'utf8' codec can't decode byte 0xf6 in position 8: invalid start byte
trac at osgeo.org
Wed Jul 1 10:41:28 PDT 2015
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.1
Component: Default | Version: svn-trunk
Resolution: | Keywords: utf, wxgui
CPU: x86-32 | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:12 hellik]:
> Replying to [comment:11 martinl]:
> > Replying to [comment:10 martinl]:
> > > Replying to [comment:9 marisn]:
> > > adding just a u' ' would not introduce problems elsewhere :(
Backporting r64834 could help in some cases but an overhaul of any string
processing in wxgui is required with strict rules (that need to be
created).
> > > it's already done in r65462
> > Helmut, could you please test current 7.0.1svn if it still works (1)?
> > (1) http://wingrass.fsv.cvut.cz/grass70/
> tested with
> GRASS Version: 7.0.1RC1
> GRASS SVN Revision: 65472
> Erstellungsdatum: 2015-06-15
> Build Platform: i686-pc-mingw32
> GDAL/OGR: 1.11.2
> PROJ.4: 4.8.0
> GEOS: 3.4.2
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
> Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
tested in german locale!
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:13>
