[GRASS-dev] [GRASS GIS] #2701: Grass 7.0.0 installed from QGIS Repository
trac at osgeo.org
Thu Jul 2 20:30:19 PDT 2015
Reporter: rjhale1971 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Default | Version: 7.0.0
Resolution: | Keywords: linux, qgis
CPU: Unspecified | Platform: Linux
Comment (by wenzeslaus):
Replying to [ticket:2701 rjhale1971]:
> Tried to add the isochrone extension and received an error.
> GException: Unable to load extensions. 'svn' required.
> Please install 'svn' first.
> I'm not sure is svn needs to be installed in python or ubuntu
`svn` refers a command line tool for a //Subversion// revision control
system. So you need to install it to Ubuntu, not Python.
Do you have a suggestion how to change the wording, so it is more
understandable what to install? (We have somewhere else also the case when
the thing to install is a Python package (e.g., *matplotlib*) but it is
still usually installed as an Ubuntu package, although some people may
prefer to install it to using a Python way such as `pip`.)
About the QGIS repository, I think you would get same issue with any repo,
but I might be wrong about that. `svn` (//Subversion//) is not a
requirement, although it is necessary for installing addons (on unix-like
systems). So `svn` is an additional or recommend dependency.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2701#comment:1>
