[GRASS-dev] [GRASS GIS] #2702: G7: vector vrt not recognized by "v.in.ogr - import common formats"/can't be opened
GRASS GIS trac at osgeo.org
Fri Jul 3 05:35:01 PDT 2015
be opened
 Reporter:  hellik       |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.0.1
Component:  Default      |    Version:  svn-releasebranch70
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 given a vector vrt (referring to a point csv):
 ogrinfo gbif_to_gis_working.vrt
 INFO: Open of `gbif_to_gis_working.vrt'
       using driver `VRT' successful.
 1: gbif_gisinput (Point)
 Layer name: gbif_gisinput
 Geometry: Point
 Feature Count: 182
 Extent: (0.000000, 0.000000) - (13.240250, 47.282780)
 Layer SRS WKT:
 GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.257223563,
             AUTHORITY["EPSG","7030"]],
         TOWGS84[0,0,0,0,0,0,0],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0,
         AUTHORITY["EPSG","8901"]],
     UNIT["degree",0.0174532925199433,
         AUTHORITY["EPSG","9108"]],
     AUTHORITY["EPSG","4326"]]
 gbifid: String (0.0)
 xdatasetkey: String (0.0)
 occurrenceid: String (0.0)
 kingdom: String (0.0)
 phylum: String (0.0)
 xclass: String (0.0)
 xorder: String (0.0)
 family: String (0.0)
 genus: String (0.0)
 species: String (0.0)
 infraspecificepithet: String (0.0)
 taxonrank: String (0.0)
 scientificname: String (0.0)
 countrycode: String (0.0)
 locality: String (0.0)
 publishingorgkey: String (0.0)
 decimallatitude: String (0.0)
 decimallongitude: String (0.0)
 elevation: String (0.0)
 elevationaccuracy: String (0.0)
 depth: String (0.0)
 depthaccuracy: String (0.0)
 eventdate: String (0.0)
 xday: String (0.0)
 xmonth: String (0.0)
 xyear: String (0.0)
 taxonkey: String (0.0)
 specieskey: String (0.0)
 basisofrecord: String (0.0)
 institutioncode: String (0.0)
 collectioncode: String (0.0)
 catalognumber: String (0.0)
 recordnumber: String (0.0)
 identifiedby: String (0.0)
 rights: String (0.0)
 rightsholder: String (0.0)
 recordedby: String (0.0)
 typestatus: String (0.0)
 establishmentmeans: String (0.0)
 lastinterpreted: String (0.0)
 mediatype: String (0.0)
 issue: String (0.0)
 OGRFeature(gbif_gisinput):4
   gbifid (String) = 684164905
   xdatasetkey (String) = 7b904404-f762-11e1-a439-00145eb45e9a
   occurrenceid (String) =
   kingdom (String) = Plantae
   phylum (String) = Magnoliophyta
   xclass (String) = Magnoliopsida
   xorder (String) = Asterales
   family (String) = Asteraceae
   genus (String) = Jacobaea
   species (String) = Jacobaea incana
   infraspecificepithet (String) =
   taxonrank (String) = SPECIES
   scientificname (String) = Senecio carniolicus Willd.
   countrycode (String) = AT
   locality (String) = Aufstieg Roßtal (Maxer Lek) - Kalksteiner Jöchl
   publishingorgkey (String) = f9912a00-84a9-11d9-8952-b8a03c50a862
   decimallatitude (String) = 46.82056
   decimallongitude (String) = 12.29528
   elevation (String) = 2175.0
   elevationaccuracy (String) = 175.0
   depth (String) =
   depthaccuracy (String) =
   eventdate (String) = 2001-08-13T00:00Z
   xday (String) = 13
   xmonth (String) = 8
   xyear (String) = 2001
   taxonkey (String) = 6064702
   specieskey (String) = 5388625
   basisofrecord (String) = HUMAN_OBSERVATION
   institutioncode (String) = TLMF
   collectioncode (String) = Tiroler Landesmuseum Ferdinandeum
   catalognumber (String) = 1AD3DA9D-845D-4432-8A78-8527951513C9
   recordnumber (String) =
   identifiedby (String) =
   rights (String) =
   rightsholder (String) =
   recordedby (String) = Polatschek A.
   typestatus (String) =
   establishmentmeans (String) =
   lastinterpreted (String) = 2014-06-05T14:10Z
   mediatype (String) =
   issue (String) = COORDINATE_ROUNDED;GEODETIC_DATUM_ASSUMED_WGS84
   POINT (12.29528 46.82056)
 ogrinfo gives the right infos about the point vector.
 v.in.ogr -f
 Supported formats:
  ESRI Shapefile (rw): ESRI Shapefile
  VRT (ro): VRT
 (1) the "v.in.ogr - import common formats"-GUI seems not to recognize the
 vrt format:
 open this special GUI, insert the path to the vrt, only a shape file in
 this file is recognized, but not the vector vrt
 (2) open v.in.ogr --ui:
 v.in.ogr -l
 input=C:\tmp\0000402-150615163101818_senecio_carniolicus\gbif_to_gis_working.vrt
 output=check4
 gbif_gisinput
 ERROR 1: Failed to open datasource `gbif_gisinput.csv'.
 Data source
 <C:\tmp\0000402-150615163101818_senecio_carniolicus\gbif_to_gis_working.vrt>
 (format 'VRT') contains 1 layers:
 v.in.ogr
 output=check5
 Check if OGR layer <gbif_gisinput> contains polygons...
 Importing 0 features (OGR layer <gbif_gisinput>)...
 Erstelle Topologie für die Vektorkarte <check5 at newcheck>...
 Registriere Primitive...
 0 primitives registered
 0 Vertices registriert
 Erzeuge Flächen...
 0 areas built
 0 isles built
 Füge Inseln hinzu...
 Füge Zentroide hinzu...
 Anzahl der Knoten: 0
 Anzahl der Primitive: 0
 Anzahl der Punkte: 0
 Anzahl der Linien: 0
 Anzahl der Grenzen: 0
 Anzahl der Zentroide: 0
 Anzahl der Flächen: 0
 Anzahl der Inseln: 0
 any idea?
 (vrt and csv attached to ticket)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2702>
