[GRASS-dev] [GRASS GIS] #2703: 'ascii' codec can't decode byte 0xf6 in position 12: ordinal not in range(128)
GRASS GIS trac at osgeo.org
Sat Jul 4 04:03:14 PDT 2015
range(128)
 Reporter:  hellik       |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  critical     |  Milestone:  7.0.1
Component:  Default      |    Version:  svn-releasebranch70
 Keywords:               |        CPU:  x86-64
 Platform:  MSWindows 7  |
 refering to http://lists.osgeo.org/pipermail/grass-
 dev/2015-July/075646.html
 now tested with
 GRASS Version: 7.1.svn
 GRASS SVN revision: 65537
 Build date: 2015-07-03
 Build platform: i686-pc-mingw32
 GDAL: 1.11.2
 PROJ.4: 4.8.0
 GEOS: 3.4.2
 SQLite: 3.7.17
 Python: 2.7.4
 wxPython: 2.8.12.1
 Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
 example 1 - v.to.db
 choose layer from vector drop down menue:
   File "C:\OSGEO4~2\apps\grass\grass-7.1.svn\gui\wxpython\gu
 i_core\forms.py", line 2221, in OnSetValue
 self.OnUpdateValues(event)
 i_core\forms.py", line 628, in updateValuesHook
 self.SetStatusText('
 '.join(self.notebookpanel.createCmd(ignoreErrors = True)))
 UnicodeDecodeError
 'ascii' codec can't decode byte 0xf6 in position 11: ordinal
 not in range(128)
 - choose option e.g. coor from drop down menue:
 UnicodeDecodeError
 not in range(128)
 UnicodeDecodeError
 range(128)
 => no entry in the drop down menue for choosing columns
 example 2 - v.patch
 UnicodeDecodeError
 not in range(128)
 example 3 - r.param.scale
 choosing layer from raster drop down menue:
 UnicodeDecodeError
 not in range(128)
 example 4 - invoking v.db.addcolumn
 i_core\forms.py", line 2056, in OnUpdateDialog
 self.parent.updateValuesHook()
 UnicodeDecodeError
 not in range(128)
 otherwise choosing layer from drop down menue works for e.g.
 d.vect
 g.copy
 g.remove
 all works if I change locale to english
Ticket URL: <https://trac.osgeo.org/grass/ticket/2703>
