[GRASS-dev] error g.gui.animation when using changing region
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Jul 6 11:08:57 PDT 2015
Hi, when I define to regions in g.gui.animation (under the advanced tab),
and press OK and OK again, the 'Rendering map layers' gets as far as (3 out
of 12) and then the g.gui.animation freezes. Error messages in the console
below.
Any idea whether this is a bug or if I am doing something wrong?
Paulo
g.gui.animation strds=tmean at Worlclim
Description:
Manages the boundary definitions for the geographic region.
Keywords:
general, settings
Usage:
g.region [-dsplectwmn3bgau] [region=name]
[raster=name[,name,...]]
[raster_3d=name] [vector=name[,name,...]] [n=value]
[s=value]
[e=value] [w=value] [t=value] [b=value] [rows=value]
[cols=value]
[res=value] [res3=value] [nsres=value] [ewres=value]
[tbres=value]
[zoom=name] [align=name] [save=name] [--overwrite]
[--help]
[--verbose] [--quiet] [--ui]
Flags:
-d Set from default region
-s Save as default region
Only possible from the PERMANENT mapset
-p Print the current region
-l Print the current region in lat/long using the
current ellipsoid/datum
-e Print the current region extent
-c Print the current region map center coordinates
-t Print the current region in GMT style
-w Print the current region in WMS style
-m Print region resolution in meters (geodesic)
-n Print the convergence angle (degrees CCW)
The difference between the projection's grid north
and true north, measured at the center coordinates of the
current region.
-3 Print also 3D settings
-b Print the maximum bounding box in lat/long on WGS84
-g Print in shell script style
-a Align region to resolution (default = align to
bounds, works only for 2D resolution)
-u Do not update the current region
--o Allow output files to overwrite existing files
--h Print usage summary
--v Verbose module output
--q Quiet module output
--ui Force launching GUI dialog
Parameters:
region Set current region from named region
raster Set region to match raster map(s)
raster_3d Set region to match 3D raster map(s) (both 2D
and 3D values)
vector Set region to match vector map(s)
n Value for the northern edge
s Value for the southern edge
e Value for the eastern edge
w Value for the western edge
t Value for the top edge
b Value for the bottom edge
rows Number of rows in the new region
cols Number of columns in the new region
res 2D grid resolution (north-south and east-west)
res3 3D grid resolution (north-south, east-west and
top-bottom)
nsres North-south 2D grid resolution
ewres East-west 2D grid resolution
tbres Top-bottom 3D grid resolution
zoom Shrink region until it meets non-NULL data
from this raster map
align Adjust region cells to cleanly align with this
raster map
save Save current region settings in named region
file
ERROR: g.region: Sorry, <projection> is not a valid
parameter
ERROR: g.region: Sorry, <zone> is not a valid parameter
Process Process-27:
File "/usr/lib/python2.7/multiprocessing/process.py", line
258, in _bootstrap
self.run()
114, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/animati
on/provider.py", line 493, in RenderProcess2D
os.environ['GRASS_REGION'] = gcore.region_env(**region)
File "/usr/local/grass7/grass-7.1.svn/etc/python/grass/scr
ipt/core.py", line 1003, in region_env
s = read_command('g.region', flags=flgs, **kwargs)
ipt/core.py", line 427, in read_command
return handle_errors(returncode, stdout, args, kwargs)
ipt/core.py", line 312, in handle_errors
returncode=returncode)
CalledModuleError: Module run None ['g.region', '-ug',
'e=47.9916666667', 'projection=3', 'zone=0', 'n=14.9',
's=3.31666666667', 'w=32.9916666667',
'ewres=0.0188442211055', 'nsres=0.024540960452'] ended with
error
Process ended with non-zero return code 1. See errors in the
(error) output.
Description:
Keywords:
general, settings
Usage:
[s=value]
[cols=value]
[tbres=value]
[--help]
Flags:
current region.
Parameters:
and 3D values)
top-bottom)
raster map
file
parameter
Description:
Keywords:
general, settings
Usage:
[s=value]
[cols=value]
[tbres=value]
[--help]
Flags:
current region.
Parameters:
and 3D values)
top-bottom)
raster map
file
parameter
Process Process-28:
258, in _bootstrap
self.run()
114, in run
'e=45.0583333333', 'projection=3', 'zone=0',
'n=12.3696969697', 's=4.51363636364', 'w=35.0613636364',
'ewres=0.012559007157', 'nsres=0.0166441961993'] ended with
error
(error) output.
Process Process-29:
258, in _bootstrap
self.run()
114, in run
'e=44.325', 'projection=3', 'zone=0', 'n=11.7371212121',
's=4.81287878788', 'w=35.5787878788',
'ewres=0.0109877036699', 'nsres=0.0146700051361'] ended with
error
(error) output.
Description:
Keywords:
general, settings
Usage:
[s=value]
[cols=value]
[tbres=value]
[--help]
Flags:
current region.
Parameters:
and 3D values)
top-bottom)
raster map
file
parameter
Process Process-30:
258, in _bootstrap
self.run()
114, in run
'e=40.6583333333', 'projection=3', 'zone=0',
'n=8.57424242424', 's=6.30909090909', 'w=38.1659090909',
'ewres=0.0031311862342', 'nsres=0.00479904982024'] ended
with error
(error) output.
(Mon Jul 6 20:02:42 2015) Command finished (52
sec)
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150706/acd5703f/attachment-0001.html>
