[GRASS-dev] [GRASS GIS] #2353: v.univar says type not supported instead of column does not exist
trac at osgeo.org
Tue Jul 7 20:29:44 PDT 2015
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: trivial | Milestone: 7.1.0
Component: Database | Version: svn-trunk
Resolution: fixed | Keywords: v.univar, vector, messages
CPU: Unspecified | Platform: All
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
I can't reproduce it either:
> v.univar map=hospitals column='ANGLE'
minimum: 0
maximum: 1
range: 1
sum: 133
> v.univar map=hospitals column='XXX'
ERROR: Column <XXX> not found in table <hospitals>
I searched logs ([https://trac.osgeo.org/grass/log/grass/trunk/lib/db db
lib] and [https://trac.osgeo.org/grass/log/grass/trunk/vector/v.univar
v.univar]) and it was fixed in r63889 by martinl (backported in r63891).
Thanks, Martin!
Closing as fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2353#comment:2>
