[GRASS-dev] [GRASS GIS] #2702: G7: vector vrt not recognized by "v.in.ogr - import common formats"/can't be opened
GRASS GIS trac at osgeo.org
Thu Jul 9 04:55:49 PDT 2015
be opened
  Reporter:  hellik       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.1
 Component:  Default      |    Version:  svn-releasebranch70
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Or you can change the line to:
 <SrcDataSource relativeToVRT=1>gbif_gisinput.csv</SrcDataSource>
 and then it works, whatever your CWD, as long as the csv file is in the
 correct relative position to the vrt file (in this case in the same
 directory).
 BTW: I have no problems using the wxgui import wizard to import this vrt.
 Have you made sure that the wizard file picker was not configured to only
 look for shapefiles ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2702#comment:2>
