[GRASS-dev] Fwd: Re: [gdal-dev] Setting NODATA to -nan
Markus Neteler neteler at osgeo.org
Thu Jul 16 06:04:26 PDT 2015
Hi devs,
FWD of an issue with r.out.gdal in G7. Any ideas?
Markus
---------- Forwarded message ----------
Date: Thu, Jul 16, 2015 at 2:07 AM
Subject: Fwd: Re: [gdal-dev] Setting NODATA to -nan
To: neteler at osgeo.org
Hi Markus,
Below you'll find the original report about what discussed on the way to the
party tonight, and then my analysis. The GDAL ticket with the dataset is
https://trac.osgeo.org/gdal/ticket/6036
I'm not sure there's really an issue in practice on the GDAL side. It is just
that dealing with nan is odd to anybody (and the way Windows and Linux
displays nan as a string is different).
Even
From:   Homme Zwaagstra <hrz at geodata.soton.ac.uk>
To:     gdal-dev <gdal-dev at lists.osgeo.org>
Date:   Yesterday 11:21:54
Hello,
I've got the following raster exported from GRASS using `r.out.gdal`:
gdalinfo ppp-2015.tif
Driver: GTiff/GeoTIFF
Files: ppp-2015.tif
        ppp-2015.tif.aux.xml
Size is 432017, 216009
Coordinate System is:
GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.257223563,
             AUTHORITY["EPSG","7030"]],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0],
     UNIT["degree",0.0174532925199433],
     AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.000833300541414,-0.000833298612558)
Metadata:
   AREA_OR_POINT=Area
Image Structure Metadata:
   COMPRESSION=DEFLATE
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-180.0000000,  90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
Lower Left  (-180.0000000, -90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"S)
Upper Right ( 180.0000000,  90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"S)
Center      (   0.0000000,   0.0000000) (  0d 0' 0.01"E,  0d 0' 0.01"N)
Band 1 Block=256x256 Type=Float32, ColorInterp=Gray
   NoData Value=nan
   Metadata:
     COLOR_TABLE_RULES_COUNT=5
     COLOR_TABLE_RULE_RGB_0=0.000000e+00 1.681282e+03 255 255 0 0 255 0
     COLOR_TABLE_RULE_RGB_1=1.681282e+03 3.362563e+03 0 255 0 0 255 255
     COLOR_TABLE_RULE_RGB_2=3.362563e+03 5.043845e+03 0 255 255 0 0 255
     COLOR_TABLE_RULE_RGB_3=5.043845e+03 6.725127e+03 0 0 255 255 0 255
     COLOR_TABLE_RULE_RGB_4=6.725127e+03 8.406408e+03 255 0 255 255 0 0
     Generated_with=GRASS GIS 7.0.0
As you can see the NoData is set to `nan`.  However, within the data it is
actually `-nan`:
gdallocationinfo ppp-2015.tif -wgs84 42.0776 30.9305
Report:
   Band 1:
     Value: -nan
I have tried to force the NoData to `-nan` as follows but with no joy:
gdal_translate -a_nodata '-nan' -of VRT ppp-2015.tif ppp-2015.vrt
gdalinfo ppp-2015.vrt
Driver: VRT/Virtual Raster
Files: ppp-2015.vrt
        /data/data/ppp_v2c_2015/ppp-2015.tif
GEOGCS["WGS 84",
     DATUM["WGS_1984",
Metadata:
   AREA_OR_POINT=Area
   INTERLEAVE=BAND
Corner Coordinates:
Band 1 Block=128x128 Type=Float32, ColorInterp=Gray
   NoData Value=nan
   Metadata:
Even editing the VRT to contain `<NoDataValue>-nan</NoDataValue>` yields a
positive nan value in gdalinfo.
This looks like it might be a GDAL bug to me?  Is there a way I can specify
`-nan` as the NODATA value for this dataset without regenerating it
(it's quite
large)?
Many thanks,
Homme
----------  Forwarded Message  ----------
Subject: Re: [gdal-dev] Setting NODATA to -nan
Date: Wednesday 15 July 2015, 20:02:11
To: Homme Zwaagstra <hrz at geodata.soton.ac.uk>
CC: gdal-dev at lists.osgeo.org
> Thanks Even,
> I have submitted <https://trac.osgeo.org/gdal/ticket/6036> with an
> attached TIFF
> infested with `-nan` values.
> While researching this I cam across this question
> <http://stackoverflow.com/q/3772835> which might contain some information of
> interest.
Hum looking more closely at representation of nan values in IEEE754, there is
at least 12 million different ways of representing nan for a 32bit floating
point value. And you can indeed have signed NaN... But I'm not sure it is
really useful to set "-nan" as the declared nodata value (it is stored as a
string in GeoTIFF) since even 2 NaN values that could be printed in text form
as "-nan" could have a different binary representation.
The parts of GDAL that test pixel values against nodata have normally a
special behaviour  to test the pixel values against nodata, when the nodata
value is one of the NaN values, so I wouldn't expect this apparent
inconsistency to cause problems
For example when running gdalinfo -stats on your file, I get :
ERROR 1: negative-nan-example.tif, band 1: Failed to compute statistics, no
valid pixels found in sampling.
Which is expected since all pixels are set to nan (-nan yeah...), so
ComputeStatistics() actually managed to match the declared nan with the -nan
as pixel values. (which is quite ironical since a property of nan is that nan
!= nan, but here nan ~= -nan ;-) )
Did you run into particular problems beyond this apparent mismatch ?
Even
http://www.spatialys.com
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
