[GRASS-dev] [GRASS GIS] #2386: wxGUI: check for old vector topology format
GRASS GIS trac at osgeo.org
Fri Jul 17 01:14:19 PDT 2015
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.0.0
 Component:  wxGUI        |    Version:  unspecified
Resolution:               |   Keywords:  v.build.all
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:7 martinl]:
 > Probably we could have a new addon module called `v.convert.g6` doing
 conversion from GRASS 6 to GRASS 7 (v.build + v.db.connect)?
 might be a nice convenience module. But just v.db.connect won't be enough
 if you want to change from dbf to sqlite. The easiest would probably be
 db.connect + g.copy + g.rename, or something like that.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2386#comment:8>
