[GRASS-dev] [GRASS GIS] #2386: wxGUI: check for old vector topology format
trac at osgeo.org
Fri Jul 17 02:43:55 PDT 2015
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords: v.build.all
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:9 martinl]:
> Replying to [comment:8 mlennert]:
> > Replying to [comment:7 martinl]:
> > > Probably we could have a new addon module called `v.convert.g6`
doing conversion from GRASS 6 to GRASS 7 (v.build + v.db.connect)?
> > might be a nice convenience module. But just v.db.connect won't be
enough if you want to change from dbf to sqlite. The easiest would
probably be db.connect + g.copy + g.rename, or something like that.
> not really, see (1)
Right, forgot about v.db.reconnect.all.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2386#comment:10>
